Help: dash lights warning lights...
I recently started to put my 90 944 s2 back on the road.
a few things happened and i am lost.
i tried to wire a radio in and the harness was already hacked up so i cut it out but when i did the check engine light ! seat belt light and air bag light went on. so i put it all back to how it was( ithink) but the lights stayed on.
anybody know how i can get them back off?????
also the shaft on my power steering pump popped out partially and the power steering stopped working. i can push it back in and it will work temporarily but pops back out. is there a piece missing? do i have to replace the whole thing? or are there rebuild kits?
Old 02-28-2009, 01:32 PM
rattlesnakeracing
alantica's Avatar
Radio Wiring
I don't know if the fault is being retained, if so, disconnect your battery for a few minutes, then reconnect it and see if they go away.
These are the common lights that come on when power is applied, then go off. I think you have cut the feedback wire, most likely a ground wire that makes the lights shut off.
You can look in the PET wiring diagrams to find out exactly what the color of the wire is you cut. Example {Black/Green; Brown} at http://www.the944.com/ go all the way to the bottom on the left hand side. The PET version you want is #6.
I've looked in the Haynes manual and could not find a reference.
87 Charcoal Metallic 944{Proj} 88 White Pearl 944{Daily Driver}
87 Silver Mazda RX-7{210K no rbld} 87 Charcoal Mazda RX-7 GSL{Proj} 88 Gold Met RX-7{Parts} 89 Midnight Black Mazda RX-7 Conv.{Proj}
87 Intl. Scout II{Proj} 99.5 Nissan Pathfinder LE {Daily Driver}
USAF (Ret) GO Blue! - - RattlesnakeRacing - Don't Tread on Me!
Old 02-28-2009, 02:50 PM
rattlesnakeracing
alantica's Avatar
Porsche Crest Radio Wiring
Need to point you in a different direction. Look at Vol4x-electrical page #240 and it shows the schematic. It looks like you have cut a brown wire which is the connection point passenger side ground to the Airbag Control Unit.
If this is the wire you cut, you probably don't have airbag support.
Need to disconnect the battery before messing with the wiring because it is easy to ground a line on unknown wiring and pop the airbags. Also the big Yellow/Black wires go to the bags and if you happen to cut one of those, it will pop a bag.
Old 02-28-2009, 03:27 PM
dkbautosports.com
962porsche's Avatar
you will have to take the car to the dealer to reset the SRS (air bag ) light . my cost 80 dollars your going to pay more ? around 125 dollars .
Old 02-28-2009, 05:05 PM
Will program for food
ghnat's Avatar
If your 90 S2 is like mine you can reset the airbag following Clarks garage instructions. http://www.clarks-garage.com/
Also look at this thread, I posted a few pics...
S2 Airbag question
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 02-28-2009, 05:31 PM
i have disconnected the battery and let it sit for a while and the lights are still on.
i went to the PET6 and it didnt go into the wiring. there are pages missing...
i will try and do the airbag reset but not sure if this will help cause its not just the air bag light that is stuck on. the reason the three lights are on must be linked. i assume since they went on at the time when i cut the radio harness
anybody know about the power steering pump?
thanks
Old 03-01-2009, 05:41 PM
ghnat's Avatar
I too had all 3 lights on. If your airbag hardware is good, resetting will turn out all three lights. It may take a few tries. Clarks has information on fault codes, if something is wrong.
Greg Hnat
98 Jeep Cherokee
Old 03-01-2009, 06:27 PM
ok cool. the only problem is i cant find the molex.
Old 03-01-2009, 07:05 PM
thank u so much. i found it and it worked.
now if i can just get the power steering issue taken care of
thanks again
Old 03-01-2009, 07:36 PM
rattlesnakeracing
alantica's Avatar
Thumbs up Power Steering
Great job on the light problem. The reason that all lights were on is because of the airbag control unit. An individual fault would light a single light, but the ground being cut (if that was the case) causes a fault on the unit itself thereby lighting all of the lights.
For the power steering pump: http://dcauto.gotdns.com/illustration/index/807614805 gives a parts breakdown of your pump. Take a look at that and see if you can get a part number. The part number will help others users know exactly what you are referencing.
Also, you may want to repost this as a power steering problem or bump it up to the top of the list. Good Luck!
Old 03-02-2009, 01:09 PM
