Lug nuts with Boxster Wheels
I'm planning to get some Boxster or 996 twist wheels for my 944. Will I need to get new lug nuts too? Are the lug holes smaller that I need smaller nuts?
You guys are great help,
Rick
-Rick Central PA
1989 Linen Grey Metallic 944 Automatic (Daughter's first car)
1984 Slate Blue Metallic 911 Cabriolet ROW, 220 WHP, Steve Wong Chip, Fabspeed Muffler, Cat Bypass.
1987 Black 944S - SOLD 1969 Aubergine 911T - SOLD
Old 03-02-2009, 06:36 AM
Nope, the old lug nuts will work just fine.
Good luck, George Beuselinck
Old 03-02-2009, 11:43 AM
Rick,
I have a set of 996 hollow twists for sale if you are interested.
FS: 17” Hollow Twists
Lucky owner of a couple of 911’s and a 924
Old 03-02-2009, 01:53 PM
Wheels
Karl- I like those wheels but I was looking for a set with tires, mostly to keep the $ down. You would have been within driving distance too. I'll keep them in mind if I come across a set of tires.
Thanks, Rick
-Rick Central PA
Old 03-03-2009, 06:18 AM
flash968's Avatar
if you are using aluminum lug nuts, you need new ones if they have been on and off the car more than 25 times - they begin to lose their ability to hold full torque beyond that point - you will see evidence of it by the tiny fragments on the threads
you need steel ones if you use spacers
you need steel ones if you plan to track the car
you should use steel ones if you drive hard, or the wheel and/or tire widths and/or net weights increased significantly
Old 03-03-2009, 06:23 AM
