My 84 NA ran a bit hot (I'm in Florida) - replaced radiator...installed low temp sensor and thermostat plus ALL fan related & A/C relays...recharged & bled... NOW it doesn't get to the first bar on the temp gauge.
Proprietoristicly Refined
The giveaway to the coolant loss is the brief white smoke when starting the engine. You obviously have coolant leaking into a cylinder which is escaping with the exhaust. I have seen this and it was fixed with a new head gasket. If you are losing that much coolant you are also getting air in the system
causing overheating.I just live with the mess caused by the minor oil leaks. |
1984 porsche 944 na
That's because your car is a bad ass car.....
