Experience With E3 Plugs?
has anyone tried the E3 plugs in a 944?
ive used them in a corvette and thought they were very good. time to change plugs and wanted some feedback. thanks |
Proprietoristicly Refined
You will not see any improvement with the e3 plugs- http://www.e3sparkplugs.com/. Simply, the computer in your 1987 944 is designed for the single copper tip plug. $.99 on sale. The plug tip allows for complete combustion of fuel supplied by the injector.
You will notice better operation with new wires or cap and rotor if yours are aged. Grab your distributer cap and try to turn/move. If it feels easy/loose, get a new cap. The hold down pins and springs have worn and you may have improper rotor to cap clearance. GL John_AZ 1988 924S 59K + 1987 924S 112K 1979 924 + 1977.5 924 + 1970 914 1.7 +++===gone, past tutors |
