-   -   will car run without alarm module? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/463407-will-car-run-without-alarm-module.html)
callmethewander 03-17-2009 08:41 AM
I removed the alarm module to bypass it as per clarks garage, but i busted the whole thing up in the process, can I just leave it out and jumper the terminals like clark says?
944 Ecology 03-17-2009 09:48 AM
Yep.
callmethewander 03-17-2009 05:48 PM
thx George
porsche4life 03-17-2009 09:16 PM
I have an extra if you ever decide you need a good one again.
callmethewander 03-18-2009 09:09 AM
thx Sydney, I may want it, I still can't get this thing running, I jumped out pins 1&4, 7&8 on the big connector and nothing on the small one, but it seems like the small one may be involved somehow because I first accidentily jumped pin 1 from the small conn. to pin 4 of the big conn. and all the dash lights came on as if i had the key in the run position, which I did not at the time. ??? I don't know what's going on, I might also have a bad DME, I know my relay and fuses are good and I'm getting good fuel pressure, just no spark.
Wipeout 03-18-2009 09:13 AM
Which car is it? Different alarms in each of the ones listed in your sig.
porsche4life 03-18-2009 11:15 AM
Ya they are different. I have a DME and alaram module out of an 86 if you are interested let me know
Wipeout 03-18-2009 11:21 AM
Not only is 88-89 different, 91 is yet another different one.
callmethewander 03-18-2009 05:42 PM
This one is an '87 na, i bought it not running, so it could be almost anything i guess, but like i said i know the relays are good and i have good fuel pressure, just no spark. Porsche 4life i am interested if the '86 is the same, i think it is.
porsche4life 03-18-2009 09:30 PM
The dme tested good by 944 ecology. I assume the alarm mod is good. I will throw it in if you buy the DME.
Pics.
http://i282.photobucket.com/albums/k...r/SANY0865.jpghttp://i282.photobucket.com/albums/k...r/SANY0892.jpg
