 Bouncy Gauges I've been driving the car all week after the DME fix and yesterday my gauges started to get jumpy, especially the temp gauge.  If I turn on the headlight it will jump up about 4 mm, turn signal will cause it to bounce in unison, basically anything electrical in the car seems to directly effect the gauge.  I've recently cleaned main ground and pulled instrument cluster a while back and cleaned footballs, changed lights.  Any other grounds I'm missing or common shorts?? |
 Give all the ground points a once over. That solved most of the issues i had with erratic gauges on my '87 n/a. The final fix was replacing all the of the battery cables. Check out this thread i made with specific details on each grounding point. http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/422736-late-interior-groud-point-locations.html?highlight=grounds |
 Thanks, that's actually the thread I read when I originally did the grounds.  Are there two in the rear hatch because I could only find one(two shown on diagram)?  Also, it looks like your 951 has a ground by the ICV bypass and the cruise control module that aren't present in the NA.  If that's true, I cleaned all grounds.  I guess battery cables could be it, it's strange that it's only affecting the temp gauge??? |
 The grounds by the test port and cruise module are actually only for the brake pad wear sensors. Double check the leads on your water temp gauge. Give them a good cleaning and make sure the wires are still intact. The spade connectors were pretty badly corroded and the insulation had cracked off. I cut the bad portion out and soldered in new wires with spade connectors. |
 Pad wear sensors, huh.  I wonder where mine went?  I tightened down the temp sensor spade connectors when I had the manifold off a few week ago but the wire did look pretty beat.  Man that thing is hard to get at with manifold on!!  There's got to be a wire or something loose somewhere, the problem is finding it.  This past week was the first time I really drove the car consistently so maybe something just came loose- now that I think about it the car was hard to start yesterday and today (four or five cranks).  All week it was starting on first or second crank, could be related. |
| All times are GMT -8. The time now is 09:39 PM. |
