pontifex4's Avatar
Brake dust shields?
I'm not sure what to call the black, plate-shaped thin metal things which sit behind each brake disc, but I assume they're dust shields.
I'm upgrading my 944S from standard to Turbo brakes, and I'm wondering if:
a) I'll need to get new ones
b) I can use my existing ones
or
c) I can do without them
Let me know what you think.
C.
Charlie
'99 996 C2 6 speed - Arctic Silver
Old 03-27-2009, 10:02 AM
That Guy
Techno Duck's Avatar
The turbo dust shields are different. You dont need them really. I took them off my n/a which had the Brembo's and also on my 951. That was with alot of daily driving and snow use also. Never had problems.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 03-27-2009, 10:35 AM
pontifex4's Avatar
Hey, Techno. A while back, I think you indicated that I would need a couple of washers to space out the rear calipers for the Turbo brake upgrade. Can you explain what's needed there?
Old 03-27-2009, 10:40 AM
That Guy
For the rear trailing arm mounting points, you just need to use a generic 1/2 inch washer inbetween the caliper and mounting point. This will space the caliper towards the inside of the car somewhat. This is the same way it was done by the factory to make up for a slightly offset caliper / pad combo, but the spacer they list is like a $6 part which looks strikingly familiar to a 1/2 inch washer .
Jon
Old 03-27-2009, 12:50 PM
pontifex4's Avatar
Ha! That's awesome, thanks!
Old 03-27-2009, 01:27 PM
Hi, all my dust shields have been removed for cooling purposes and brakes work just fine
Old 03-28-2009, 04:55 AM
In the Fires of Hell.....
kdjones2000's Avatar
I have a set of Turbo cooling ducts - Cost of shipping if you want them.
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 03-28-2009, 06:07 AM
Griffinroydonal's Avatar
Brake shields
I never put the brake shields back on any of my cars - But I don't use the brakes much . I don't use the rear view mirror much either - What starts behind me STAYS behind me.
Warning - I play with Porsche's
1970 -914 / 1982 -911
1984 -928 / 1987 -928
Old 03-28-2009, 09:11 AM
pontifex4's Avatar
Turbo ducts
Thanks, Keith.
I've sent you a PM. By the way, thanks again for the shifter!
Charlie.
Charlie
Old 03-28-2009, 11:52 AM
