speedo needle needed ???
Hi Guys,
I broke the needle on my speedo while replacing the odometer gear. Anyone have a speedo or a tach that I can buy just for the needle ? For a 85 1/2 and newer. Does anyone know if an early model needle will work and match up ? Thanks
1988 951 Alpine White / Burgandy Profec B spec II EBC,HomeBrew Chips, WideFire HG, Tial 38mm, Magnecor Wires, Koni Rears, Adj Rear Droplinks, Zeitronix WideBand. |
Just to let you know, You are not the only one to do this;
The first time I replaced a speedo gear I bent the needle pretty bad (sorry McFly) I wish I had one to send to you, But at least you know you are not the first to do this. OTR
(Mae) Red '86 944na- gettting new paint soon. (Abby) Black '86 944na- new addition to the family. |
try super glue? I have heard from someone that it works pretty good, hasnt broke-off in 7 months.
Steve- If you havent looked, look- www.clarks-garage.com 87 951 red- Maria (current) 84 944 white- Percilla (current DD) 85.5 944 red- Pinta (past) 87 924S red- Nina (past) |
That Guy
I have a spare that i kept for this very reason from a broken speedometer. I wont be able to mail it out until probably next saturday though.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
heh,heh
Thanks guys. I had a feeling it was gonna break. The needle was OK, I just broke the black plastic shroud piese, I epoxied it back and it doesnt look too bad but bad enough that it will drive me nuts.
'68 911 / '86 944
I've got a spare cluster I can pull a needle off of. Send me your info and I'll drop the needle in the mail. andyshoun@bellsouth.net.
