water in my car!
Every time it rains I get water in the back of my car. My spare tire well gets filled up along with my left brake light. None of the carpeting gets wet though. How can this water be gettign in?
1985.5 Stone Grey 944-SOLD 1987 Yellow 951- For Sale |
do a search up here.. there are plenty of threads regarding that specific problem.
in a nutshell: wheel well drain tubes/holes
''87 944na 85k C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946 '94 Oldsmobile 88 Royale (winter beater) Its not what you drive, its what drives you. |
Check your drain tubes maybe they come undone.
1986 951 1983 944 |
Make sure the drain holes going through the rear spoiler are clear of muck and twigs - if they are blocked you will get a puddle forming which drips its way into the car.
Have you looked to see if you can see it dripping when it is raining?
Andy Lowered '84 944 no longer smokin! Lowered, adjustable KONI shocks, APE chip, K&N panel filter, Strut tower brace, Blue Fuchs (+ anything else i've not discovered yet!) http://photos.yahoo.com/shineyblue944 |
The drain holes on the spoiler are clear. they direct the water over the tail lights and I think the water is coming in through there. How can I seal the openings and does this sound possible?
If you lift the side "flaps" of the hatch carpet area up on either side, there are wheel wells.. There should be tubing from your sunroof runoff that exits there. If they are cracked or not connected, water will drain right into the wheel wells.
Additionally, underneath my rear hatch pins I have plastic covers which feed into tubing that drains out from there as well. Keep us updated.
Parrothead member
Take a length of stiff wire and run it through the sunroof drain tubes , they clog up with dirt. and check the bottom of the wells behind the wheels , make sure the holes are clear
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
I have the EXACT same problem.
The water is coming from the hatch latches. it goes down into the holes and drips down the rear into the wells. I havent got mine stopped either. Next time it rains, or you wash it. Open the hatch and im sure youll see the latches and holes wet.
Current: 1973 914/4 project. FOR SALE |
The tail lamp assemblies did have a gasket type of seal originally, similar to the sealant used on the front fenders where they are bolted in. Removing the assemblies, cleaning both surfaces and using thin closed cell sponge weatherstripping might help water infiltration. But, your first line of defense is the drain hoses. Keep them clean and attched!!
Bob S. former owner of a 1984 silver 944 |
listen to livewire and vinman - I used weedwhacker line to clear the tubes in my car. If you use a stiff wire, you can poke a hole in the tube, and I have no idea how you'd replace that.
Ryan '84 944 moneysucker edition (SFR, Corbeaus, etc.) '02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's |
The two lines from the sun roof seem to be fine. The holes in the wheel wells are clear because they do drain water. Also the two lines that drain the rear hatch look good. I'm going to put the hose on the back of my car and see what happens this weekend. I still really think it's comming from the tail lights.
One other source is the glass hatch. Sometimes the glass separates from the frame and water finds its way into wierd places. One tell tale sign is that the hatch will become misaligned. Check the top of the hatch about where the hinges are located. This can be a real pain to fix...
Hoplessly cleaning my fingernails 1984 944, 1996 Jetta, 1998 New Beetle, 2001 Passat, 1997 Expedition, 2004 Yamaha FZ6, 1985 & 1987 Suzuki LT230S, 1982 Cessna 172, 1989 Bayliner Capri 5.0 HO Toys are Good. |
I did a test and confirmed that the water is leaking in from my right tail light. What is the best way to reseal the light?
Should the drain hoses go into the rear wells on each side of the car and discharge the water into the well area or should they be routed out through the drain holes and discharge the water directly out of the car?
1984 Guards Red Porsche 944 NA 2005 Suzuki Forenza 2005 Suzuki SV650 **SOLD** 2008 Toyota Siena |
Seal
I have used black sealant and a caulking gun. Remove the light and clean off all the old crap and I know it is there. Run a bead about the size of a pencil around area where old sealant was. Start to replace light and check from inside to see if you have enough sealant. tighten bolts and let dry. Leaks are a problem with most of these cars, so check all the secret places. Water and Porsche cardboard do not mix well.
Warning - I play with Porsche's ![]() 1970 -914 / 1982 -911 1984 -928 / 1987 -928 |
