Rear hatch release motor - 944S2
I need to replace the release motor for my rear hatch - in a 1989 944S2.
The release no longer works with the key - or the switch.
The fuse is OK.
Where do I find a replacement hatch motor - new or used ?
Dick
Old 04-09-2009, 05:12 PM
Mountain Road Maniac
ColoradoSteve's Avatar
Should still work with the key... try turning the key and lifting the hatch gently from different places ( left, middle right) it may just be a stuck catch.
'83 944
'87 951- SOLD!
Old 04-09-2009, 05:21 PM
Turning the key does not result in the normal motor sound - nothing happens when I turn the key left or right. Usually you can hear the release working - even if the hatch is stuck.
Old 04-09-2009, 05:27 PM
thekidd's Avatar
Send a message via AIM to thekidd
. When you manually use the key to open the hatch, the motor is not in use. If you turn the key you will hear something moving inside. That is the arms that release the hatch. Might want to try to take off the 2 black boxes (they should have drain tubes connected to them) the hooks that release the hatch may be stuck and need some oil. Thats what happened on my 924S, hatch wasnt opening smoothly, was releasing one, but not the other. I have a hatch motor (cheap beacuse it sucks when things dont work right)if you need it, send me a PM me if interested.
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 04-09-2009, 07:22 PM
In the Fires of Hell.....
kdjones2000's Avatar
Is it the '89 or '90 where they went to full electric on the rear hatch release?
I am thinking that '89 should still be mechanical with the key, so you should be able to get it open if you can turn the key. Try banging on the hatch over the pins when turning it and see if it goes.
Make sure to lube things up well before closing it again :P
Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 04-09-2009, 08:36 PM
Learned by do'n twice
I have a motor from the 86 NA I'm parting for $25. If you want it email me at:
jmd_forest@yahoo.com
86 944 NA - Brought back from the dead
Old 04-10-2009, 04:05 AM
Good luck, Keith
My 89 S2 is electrical only, so I imagine his is as well. In my case the button in the drivers' wheel well would work, but not the key.
Old 04-10-2009, 04:43 AM
