-   -   LSD part numbers ? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/469203-lsd-part-numbers.html)
Skytrooper 04-15-2009 07:42 PM
LSD part numbers ?
Does anyone have a quick reference for the LSD part numbers ?
many944s 04-16-2009 11:48 AM
Which part numbers are you looking for?
Transmission ID numbers or Porsche part numbers...
The actual Porsche part number for the LSD differential is 951-332-053-05
However....
In all of my transmission endeavors, I have found that there are 2 distinctly different versions of the LSD in these trannys! The standard LSD (found in many of the factory LSD "option" cars and the Turbos) have 4 round openings on the side of the main diff housing and usually have a much lower locking rate. In the few 944S LSD transmissions that I have opened the differential housing has oval shaped side openings, and locks up MUCH more! I have been told that the regular (round opening diff) is a %40 locker, where as the oval opening diff is an %80. whether this is technically correct or not I can not say, but from my experience you cant get the latter ones to slip by hand! it takes considerable force (or a prybay) to get the plates to slip.
Hope it helps!
-Nick
Skytrooper 04-18-2009 05:47 AM
Transmission ID numbers is what I wanted...if anyone knows them
slow944s 04-18-2009 08:44 AM
Just bought an 87 944S about a month ago. How can you determine if it has LSD or not? Thanks in advance....Jerry
earlr85944 04-18-2009 09:51 AM
http://www.clarks-garage.com/shop-manual/trans-04.htm
Skytrooper 04-18-2009 11:13 AM
That helped ! Thanks Earl !
slow944s 04-18-2009 11:29 AM
Where can I find the option code sticker on my car if it is still on it? Thanks again.
earlr85944 04-18-2009 12:36 PM
no prob
option sticker should be above the spare tire on the back trunk wall
