My friends call me, Top
Skytrooper's Avatar
944n/a in a 951 ?
I was thinking of putting a 944N/A motor in a 951 (which has a blown motor). What kind of crazy stuff would I have to do for this to be successful ? I do have a ECU for the N/A motor...what else do I need to consider ?
Please...constructive replies only, thanks
Matt
'87 924S
Old 05-01-2009, 06:23 PM
That Guy
Techno Duck's Avatar
Not a bad swap actually. You would need to the entire wire harness and DME from the n/a. and of course the full exhaust from the n/a. The transmission is debatable, the longer gearing of the 951 trans will make the already anemic 8v n/a feel even slower. The radiator is different aswell, however you can keep the 951 radiator in there and just block off the extra fitting for the turbo waterpipe.
Another thing i just thought of is the expansion tank is different, but the extra fitting can be blocked off also.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 05-01-2009, 06:32 PM
Ya it will be gutless. Whats wrong with the 951 motor?
Old 05-01-2009, 06:33 PM
Hi, why not just put in a good running 951 motor to repalce the blown one? They are around and not too terribly expensive.
Old 05-01-2009, 06:41 PM
xsboost90's Avatar
Send a message via AIM to xsboost90 Send a message via Yahoo to xsboost90
put the n/a motor in w/ the turbo components- sure it'll run alittle better..higher compression.
"Racing is life, everything else is just, waiting"
'64.5 mustang- protouring project
'08 Sierra 4x4 - daddy mobile
'13 Odyssey - mommy mobile
Old 05-02-2009, 08:10 AM
Skytrooper's Avatar
car does not currrently have a motor or transmission. I have the whole shebang out of a 84. This is why I asked...just an idea.
Matt
'87 924S
Old 05-02-2009, 02:18 PM
Arizona_928's Avatar
Originally Posted by xsboost90 View Post
put the n/a motor in w/ the turbo components- sure it'll run a little better..higher compression.
I think you need the lower compression to run a turbo...
You could get an N/A engine and build it up with some lower compression pistons.
Depending on what is wrong with the turbo one, you could probably get a good used N/A as a core, then swap parts and have a nice fresh engine... depends what what's wrong with the turbo engine tho.
dolor et pavor
Copyright
Old 05-02-2009, 03:45 PM
9.5:1 isn't really all that bad with a turbo, especially with today's higher quality gas.
Old 05-03-2009, 02:13 PM
rattlesnakeracing
alantica's Avatar
Porsche Crest Engine Swap
Skytrooper,
Does not have a motor or transmission? So, do you just have the shell with no 951 motor or transmission? Has anything else been stripped out? Pics of engine bay & what you have to work with (engine, trans., etc...) would be great. You are leaving a lot of variables open. Is this going to be a DD, track car, weekend ride around? You need to give us more info to work with to stay away from the "crazy stuff".
87 Charcoal Metallic 944{Proj} 88 White Pearl 944{Daily Driver}
87 Silver Mazda RX-7{210K no rbld} 87 Charcoal Mazda RX-7 GSL{Proj} 88 Gold Met RX-7{Parts} 89 Midnight Black Mazda RX-7 Conv.{Proj}
87 Intl. Scout II{Proj} 99.5 Nissan Pathfinder LE {Daily Driver}
USAF (Ret) GO Blue! - - RattlesnakeRacing - Don't Tread on Me!
Old 05-03-2009, 03:39 PM
