87 944S gear ratio
Hello,
Does anyone knows or can point me to where to fine the gear ratio out of the 87 944s as compare to a regular 944? Is it longer or shorter?
I'm looking in wanting a short 5th gear.
Thanks,
Old 05-04-2009, 10:59 AM
rickharrison's Avatar
Try www.clarks-garage.com, its there.
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 05-04-2009, 11:05 AM
slow944s's Avatar
I think the 87 944S has the same tranny as the turbo if I remember correctly. Don't remember what 5th gear specs are though.
84, 944 Silver--Crashed and burned.
87, 944S White--Daily driver
Old 05-04-2009, 12:33 PM
Greasy Member
many944s's Avatar
^ Nope,
The 944S trans is the same as a standard N/A trans only a little shorter gearing (including a short 5th). The R&P is the same final drive ratio as the N/A.
Hope it helps,
Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 05-04-2009, 05:14 PM
Originally Posted by many944s View Post
^ Nope,
Hope it helps,
Nick
So from what you said, it does have a shorter 5th gear as compare to the 944NA?
Old 05-05-2009, 06:40 AM
It has the same 5th as the '88 944's, and the '87-88 924S's. Earlier cars had the tall 5th
Eric Kuhns
NASA Great Lakes Super Touring Series Director
2007 & 2008 944 Spec National Champion
2015 NASA Eastern Champs 2nd place in ST2 "Franken44"
Old 05-05-2009, 08:01 AM
F944S's Avatar
As Rick Harrison stated earlier, you can find all the gearing info in Clarks Garage Shop Manual under Transaxle-Information.
Fred
'87 944S
'87 325 IS
'01 Grand Cherokee
'74 Kawi 750 H2
Old 05-06-2009, 06:08 PM
dkbautosports.com
962porsche's Avatar
this was the first time i ever went to clarks garage . they are way out of date with there trans info . there missing about 15 percent of the trans codes from what i have in my porsche factory information books . the turbo and turbo s uses the same trans and the 944 and 944s use the same trans . that is for USA car specs only ! gear ratio wise ! then its up to the trans code .thats on the out side of the trans that tells you what 5th gear and FDR that trans has . if the code can not be found then with the trans in 5th gear spin the input shaft 14 rotations . the output shaft should spin 1 time . 14 to 1 will make it 37:27 5th and FDR 9:35 . this is out of the porsche book i have .
Old 05-08-2009, 05:31 PM
