Jeff A.
Send a message via Skype™ to jbaeng
stranded with a dead battery
I'm driving my 88 944 NA this week across the country to start a new job back east next week. today going across Wyoming i noticed the voltage meeter dropping down below 12V. i thought my alternator was dead and sure enough 5 miles later the car stopped running. i got towed to Kar Kraft in Rawlins just as they were closing. they are charging the battery overnight and partsheaven is sending out an alternator overnight so i can get back on the road tomorrow. looking around the past posts here i see that if the dash bulb is out the alternator will not work also. i saw a work around using a dome light bulb connected to the battery to get the alternator working. my main concern is getting to NJ by Sunday so i can start my new job! I checked the car over quite carefully before i left to ensure i make it on time. the alternator will get checked out first thing in the morning but i do not remember seeing the charge light come on at all yesterday so i think this really can be the problem. My question is where is the bulb located once i pull the instrument cluster out? what bulb do i need to use and are they readily available?
thanks for the help!
Jeff A.
'88 944
'99 Vanagon
'03 Pilot
Old 04-22-2009, 11:24 PM
Jerome Ryals's Avatar
If an 87 is the same as an 88 the bulb should be in the middle of the dash, when mine was going out (alt) I kept seeing it come on and was thinking why was my emergency brake light coming on - it was alt light.
Old 04-23-2009, 04:49 AM
good luck jeff
Jeff
good luck on your drive.
you must be driving rt 80.
i remember driving a 1965 series landrover from WY to PA.
I only broke once.....generator in Chicago.
I still drive the rover daily and it's 27 years later.
enjoy the drive and good luck.
landrover88
1978 911sc cpe
1986 944 N/A sold to pelican
1965 series 2a 88 landrover sold
1964 series 2a 88 landrover sold
1988 944 white. sold
Old 04-23-2009, 05:00 AM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
heh... this sounds awful familiar, I was in the exact same situation back in 2001, driving from Detroit to Annapolis to start a new job in my '84 Scirocco. Convoying with my GF driving my '89 16V GTI. I was worried about the 16V making it but it was the roccet that broke down just outside Cleveland with a dead alternator. 16V ran fine the whole way...
anyway, I suspect that you don't need a whole new alternator at all. typically it is the brushes that wear out and a new brush/regulator unit will get you going again.
The alternator needs to see current on the blue wire to charge, so if you need to fool it into charging, wire a bulb between a "switched hot" source and the blue wire terminal on the back of the alt.
BTW I have a rebuilt alternator on deck in my garage for an '88 NA if you really get up fecal stream. I'm in NoVA just outside DC. We could work a trade for one of your cores if we had to, I think I paid about $200 to have it rebuilt. (expensive, but there's only one shop around here I trust. Of course my old alternator will last forever now.)
good luck
nate
1988 944... and a bunch of other cars
Old 04-23-2009, 11:46 AM
Jeff A.
Hi all, I made it to Omaha last night, the rebuilt alternator did the trick. the alternator was delivered by UPS by 10:30 and I was on the road by noon!
the good thing about the alternator breaking is as the car was loaded on the flatbed I notice the right rear wheel had a completely cracked spoke leaving four good spokes. quite scary! I had parts heaven send me a replacement wheel along with the alternator (I have 17" boxster style wheels). perhaps stopping due to the alternator prevent a catastrophic failure of the wheel? anyhow, all is well now, I'll post a picture of the wheel, I've never seen this happen before.
Jeff A.
'88 944
'99 Vanagon
'03 Pilot
Old 04-24-2009, 07:30 AM
lucky yer alternator broke down! otherwise u would have been in a ditch or worse!
Old 04-24-2009, 10:52 AM
Jeff A.
yup, i truly believe having to stop and finding the broken wheel was great luck. here is a picture of the cracked wheel. anyone ever see something like this? i would not have expected the spoke to crack. I put them on my car 4 months ago, i bought them used from a guy on craigslist that was down in LA. this wheel had a little curb rash, but overall they were in great shape. just show you "buyer beware".
Jeff A.
'88 944
'99 Vanagon
'03 Pilot
Old 05-09-2009, 02:40 PM
Jeff A.
Does anyone know the name of this wheel style?
Jeff A.
'88 944
'99 Vanagon
'03 Pilot
Old 05-09-2009, 02:42 PM
Proprietoristicly Refined
John_AZ's Avatar
2001 Boxster
http://www.wheelenhancement.com/index.php?t=WheelDetail&id=45
Glad you spotted it>
John_AZ
Old 05-09-2009, 05:12 PM
