Toofah King Bad
Rasta Monsta's Avatar
Info Needed: Fuel Pump Power Routing
Long question short. . . ON A PLASTIC TANK 944, the fuel pump power leaves a harness that goes down through the rear cargo floor (also carries reverse light switch, fuel level sender).
Somehow, from there, it goes under that funky plastic cover and to the plug that goes on the fuel pump. Can anyone give specifics in regards to routing?
TIA
rasta
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 08-02-2009, 07:31 PM
ykalinin's Avatar
would also appreciate any info w/ this issue
Old 08-04-2009, 07:20 PM
