| View Poll Results: What brake fluid do you use on your street car? | |||
| DOT 3 |
3 | 16.67% |
| DOT 4 |
12 | 66.67% |
| DOT 5 (SILICONE) |
3 | 16.67% |
| DOT 5.1 (NON SILICONE) |
0 | 0% |
| Voters: 18. This poll is closed | |||
LinkBack | Thread Tools | Rate Thread |
Brake Fluid
What Brake fluid have you used on your 944 street car? What is your favorite brand for street use?
1984 Guards Red Porsche 944 NA 2005 Suzuki Forenza 2005 Suzuki SV650 **SOLD** 2008 Toyota Siena |
Will program for food
ATE Super Blue... Great for street, auto-x and track.
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
How often do you flush your fluid to retain the high dry rating of the ATE fluid?
Some folks flush after each DE event, but they are FAR better and faster drivers than I am. I do it 2 times a year right now. The car is not much a daily as it is on jack stands more than it is on the road, but I assume it takes a bit of work to sort the car out.
winter-hater club member
ATE blue.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Will work for parts
I used to use ATE blue. Recently both the 944 and Boxster got Motul RBF600. Great stuff, but 2-3x more expensive than the super blue.
'88 944 240,100 miles -race car '05 Boxster 110,000 - Daily Driver '74 911 Targa - long term project |
The reservoir says USE ONLY DOT4. So I used the brand of DOT 4 that I could get locally.
is it 2-3X better? if so, i will be using this in the future.
I ended up going with Valvoline Synthetic DOT3 & 4 fluid, since it was available locally and met both DOT3&4.
http://www.valvoline.com/products/consumer-products/brake-fluids/dot-3-4-brake-fluid/28 Thank you for all your input, I may try ATE super blue next time.
Misunderstood User
Change fluid every other year, DOT 4, Valvoline.
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
Glorified Babysitter
I use ATE Blue in both of my cars and Castrol LMXWhatever in my wife's car. I put in fresh fluid prior to track days or change the fluid every other year, whichever comes first.
BB.
'87 Porsche 944 (toy) '90 Miata (daily driver) '04 PT Cruiser (her's) "Sometimes you're the windshield... sometimes you're the bug." |
Custom User Title
dot4 with the oil change at the start of the season.
Changing brake fluid
Can I just go back and bleed the brakes now to change the fluid in the brakes? When you do the regular brake fluid change, do you also bleed the clutch again? |
Is it possible to reach the bleeder for the clutch without removing the starter? Can this be done with the car on the ground if a pressure bleeder is used?
