-   -   removing release lever pivot shaft?? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/475690-removing-release-lever-pivot-shaft.html)
shogunther 05-21-2009 01:16 PM
According to Clarkes, I need a 8mm x 150mm bolt to remove this. The problem is I can't find this size bolt at my local hardware store. Is there a universal tool that I can rent at my local autoparts store? Any other way of removing this?
Thank you.
speedracing944 05-21-2009 01:25 PM
The shaft has a threaded hole in the end. I thread a screw in the hole and use my slide hammer to tap it out. Make sure to have the setscrew taken out before you try to remove the shaft.
Speedy:)
shogunther 05-21-2009 01:37 PM
The shaft has a threaded hole in the end. I thread a screw in the hole and use my slide hammer to tap it out. Make sure to have the setscrew taken out before you try to remove the shaft.<br>
<br>
Speedy<img src="../../ultimate/smile.gif" border="0" alt="" title="Smilie" class="inlineimg">
How long was the bolt that you used?
kdjones2000 05-21-2009 03:36 PM
I just used the longest bolt I could find at the local Ace store.
It was long enough.
mikepellegrini 05-21-2009 06:59 PM
The one I use is only about 4". I screw it in, then clamp onto it with vise grips, and then beat on the vise grips with a hammer. Works like a charm.
