Front Hub Bearings
Help. Brass would not help with taking out the front bearing races, so went to hitting with steel. Outer came out without difficulty and I thought inner did as well. But looking at the hub you see these two indentations. Will this be a problem?
1980 ROW SC
1986 944
looking for a 914
2008 4 Door Wrangler
Old 06-01-2009, 03:08 PM
Probably not a problem... The proper way to get those bearing races out is to heat the hub (with propane torch), then to use a brass drift to punch them out. Not as damaging as steel to the aluminum hub.
Good luck, George Beuselinck
Old 06-01-2009, 03:48 PM
The methods I have read have been all over........thanx! I have yet to do the other side...
1980 ROW SC
1986 944
looking for a 914
Old 06-01-2009, 04:10 PM
