Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Oil Pressure
I know that 951s seem to have their own language when it comes to gauges, but I was wondering what a 951 oil pressure gauge should nominally read when the car is hot. Mine seems to hover just around the 3-line (sometimes just underneath it) after about 20 mins of driving.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 05-27-2009, 12:34 PM
That Guy
Techno Duck's Avatar
Depends on oil weight you are using and oil temp.
At normal operating temp, warm idle should be around 2.5-3 bar using a 40w oil.. 50w is about 3-3.5 bar.
Above 2500rpm should be 4.5+ bar regardless of oil weight.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 05-27-2009, 12:37 PM
Writer/Teacher
CJFusco's Avatar
Yup, that sounds about right. It's usually at around 5bar at full throttle.
Thanks; I was just curious.
Old 05-27-2009, 01:35 PM
My 89 951S is 5 bar cold and hovers around 3 bar hot and just a hair below sometimes. I run 20-50 castrol.
Old 05-27-2009, 05:45 PM
Writer/Teacher
CJFusco's Avatar
Yup, mine's the same. I was just a little worried for awhile, when I had a clicking sound from the engine, that I might have had a bad rod bearing. I have pretty much eliminated this as the issue, which points to either a sticking lifter or an exhaust leak. I put some Marvel's Mystery Oil in my car today, and haven't heard a noise since.
Old 05-27-2009, 08:57 PM
Same. 3 or a hair under when hot. And 5 when cold.
Winter is usually slightly higher, around the 4 mark.
White 91 944 Turbo
Lindsey boost enhancer, 3 bar FPR, Bailey BOV and Promax chips.
Old 05-31-2009, 11:36 AM
