how is the tach set up on a 924s
there is a piece that goes on to the bell housing that i believed to be part of the tach, i hooked it up to the only wire that made sense but the tach didnt work, does it measure spark like some do and i actually need an internal combustion engine to make it happy or what?
Used & Abused
The tach is designed to count the sparks from the coil and is driven usually at 12v. The 2 sensors you believed could drive the tach can't. What kind of alternative engine are you using?
83 - 944, daily driver 62 - VW Karmann Ghia, never moving restoration "Oh Bother," said Pooh, as he chambered another round. |
Actually, it does, but that work is done by the DME, which then calculates when to send pulses to the ignition coil. The tach merely receives those pulses from the DME and indicates the rpms.
So, while there are pulses coming from the flywheel sensors, it doesn't convert to the tach signal directly, and, oh, by the way, the tach pulses are about 12 volts DC and the flywheel sensor pulses are about 1.5 volts DC.
Good luck, George Beuselinck |
Well, you might continue to use the DME computer to convert the flywheel pulses to an ignition coil signal, but it seems like a lot of extra weight.
It would be simpler to have an rpm indicator from the electric motor.
