Troubleshooting ideas - oil sender and radio both cut out same time
Both worked great until after I charged the battery (I have a drain somewhere I haven't tracked down) with a charger.
I checked the fuses and they looked OK. Change that one or more are actually bad? Doesn't appear to be a relay anywhere that I need to check but I'm still a newbie with my 924S still. She's an 1987 if that matters. |
X relay
Good luck, George Beuselinck |
George, I just ordered a new X-relay.
Thanks guys. |
Turns out it was just a fuse. It looked ok but was shot. New fuse and everything works again.
Thanks. |
