944 ecu?
HEy guys i was wondering if a 1989 944 ecu will work in a 1983 944. The reason i am curious is because i want to chip my car but i know that the earlier models of the 944 cannot be chipped. i was planning on buy the newer ecu and putting it in my car along with a chip. tell me what i should do guys. thanks
Old 06-08-2009, 09:09 PM
I dont think so...
Old 06-08-2009, 09:10 PM
banana944's Avatar
You can make it work but you need the other componets of the late ECU setup. Search should bring up some results.
Old 06-08-2009, 10:48 PM
winter-hater club member
nynor's Avatar
a 1989 ECU would be for the 2.7 liter. get a 1985.5 ECU and AFM. you have to change them both due to voltage differences from the 1983 parts.
"COOL PRIUS!" - Nobody Ever
Old 06-09-2009, 01:05 AM
TibetanT's Avatar
The 1989 DME/ECU cannot be supported in an older car due to the fact that your fuse panel is not a fuse box. The older, late model, 944's have forty-one (41) fuses for a reason, where as the early 944 does not.
However, I believe you would have to re-wire the harness to adapt to the earlier cars electrical system. Just doesn't seem possible or feasible. This is a BIG project, BTW.
Now, if you were planning on installing a late (1986-1989) engine from a 944 in your early car, then it may be possible, but then again, you would need to upgrade the entire wiring harness to be able to utilize all the functionality of the later car. And, install a late fuse box and relays to support the electrical capacity and components.
Just my .02 cents.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 06-09-2009, 10:28 PM
Roman944's Avatar
I think someone on rennlist said that you cam get a late DME and AFM, but I think it might have to be from the 2.5L N/A to the 2.5L N/A
let me see if I can find that topic and I'll post a link to it ...
here, not sure if this is what you are asking about though: http://forums.rennlist.com/rennforums/924-931-944-951-968-forum/500678-swapping-early-dme-to-late.html
Old 06-10-2009, 05:04 AM
Originally Posted by roman944 View Post
i think someone on rennlist said that you cam get a late dme and afm, but i think it might have to be from the 2.5l n/a to the 2.5l n/a
let me see if i can find that topic and i'll post a link to it ...
Here, not sure if this is what you are asking about though: http://forums.rennlist.com/rennforums/924-931-944-951-968-forum/500678-swapping-early-dme-to-late.html
thats exactly what i needed thanks!
Old 06-10-2009, 10:32 PM
Won't you need to swap the whole harness?
Old 06-10-2009, 11:07 PM
I have an ecu and afm out of an 86 2.5 if you are interested. Make me an offer
Old 06-10-2009, 11:08 PM
