Adjustable front shock stock on late 944
Late model 944 at the junk yard allmost untouched has adjustable front shocks. I know this because at the top of the strut I see an adjustable tab like the Komi sports I have for my early 944. The outside of the strut looks just like my early with the replaceable insert. Are these a factory option or are they posibly koni's
Regards
J
Old 07-19-2009, 11:56 AM
Non Compos Mentis
Konis were a factory option.
474 was the option code for the shocks, M030 was the code for the sport suspension, which included adjustable Koni shocks.
Old 07-19-2009, 02:10 PM
The only drawback to that option if I remember was the rears had to be removed to be adjusted.
86 951 blk
Old 07-19-2009, 04:01 PM
winter-hater club member
nynor's Avatar
er.... this doesn't sound like a drawback to me....
"COOL PRIUS!" - Nobody Ever
Old 07-19-2009, 09:11 PM
I took a picture of the option codes and matched them up and none of them were any suspention upgrades. So when I recover I we these sun burns I'll check out and see if they are Koni race or sport. Btw I found out why it's in the junk yard, a piece of the block the size of a 50 cent piece was put back with silicone ...WTH!
Old 07-20-2009, 06:39 AM
For the fronts all you had to do was open the hood and twist the top of the strut... I could dial until i found the setting that made my butt cheeks quit puckering when I went deep into a corner. The rears however, I had to remove, pull out the rubber deep inside the shock shell, compress, twist, and repeat for the opposite side. All the while hoping that you got them at about the same rate. Regardless though, when I replaced the shocks, I used the same ones.
86 951 blk
Old 07-20-2009, 06:17 PM
nynor's Avatar
yeah, but you have adjustable shocks!
Old 07-20-2009, 10:47 PM
Yep... ya got me there. I tried a set of non adjustable Sachs, but they were never as reassuring as the Konis were. They didn't last long. I replaced those with a brand new set of adjustable Konis within a couple of months. Anyway, just making conversation and putt'n in my 2 cents worth.
86 951 blk
Old 07-21-2009, 08:12 AM
