Window to door seals cracking - suggestions
Any treatment to if not stop it then at least slow it down? These are the seals that are on the top top where the window meet the door (you know, where you rest your arm when cruising around).
Thanks |
Non Compos Mentis
They are a couple decades old now. You can buy new ones here at Pelican, and you're good for a few more decades.
In the Fires of Hell.....
Yep, believe it or not but all of those door seals can be had from your Por$she dealer.
I just replaced my window guides with fresh ones , was under $60 per side.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Vaseline,
rub it in, good for rubbers should work for thoes seals
----------------------------------------------------------- The fear of God is the begining of wisdom <>< NotJustPorsche Subscribe: notjustporsche-subscribe@yahoogroups.com |
vaseline is VERY good on rubbers... makes it slide really nicely
Will program for food
I thought petroleum based stuff is bad for rubber trim pieces?
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
