Rod Schneider's Avatar
Question What Seats Do I Have?
This is my 1985.5 project car. I'm curious about what front seats these are. They are not power seats, and there was no provision for mounting the seatbelt buckle on the seat (or on the car), so they may not be original. I had to get a bit creative to install the seatbelt buckles! I'm going to have to recover them, but I need to make sure I get the right recover kit.
Here is a picture:
Thanks!
Rod Schneider
Ball Ground, GA
88 928S4, 87 Corvette,
88 Fiero GT, 16 Mustang EcoBoost
Old 10-15-2009, 03:02 PM
looks like just the normal seat.
Old 10-15-2009, 03:08 PM
Yea, is this a trick question?
Old 10-15-2009, 03:27 PM
I suspected they might be the normal seats, but not having any mounting provisions for the seat belt buckle makes me think they are not the original seats for this car. A previous owner had pretty much gutted most of the interior.
Did all years of 924/944 mount the seat belt buckle directly to the seat? I ended up drilling mounting holes to install the buckles......
Rod Schneider
Ball Ground, GA
Old 10-15-2009, 03:29 PM
Hi Rod, You can take the seat bottom cover off and it can be repaired. They will take a strip of vinyl and sew it on the back both sides of the split. It will look like a French stitch. It will really only be noticeable to you as you know it is there.
Cheers,
Larry
Old 10-15-2009, 03:45 PM
Thanks, I may give that a try. The seat backs are fairly decent.
Rod Schneider
Ball Ground, GA
Old 10-15-2009, 03:51 PM
moorepower's Avatar
Those are actually not the correct seats for an '85.5. They are from an '83 to '85, or perhaps a 924. The '85.5 and later seats have the seatbelt buckle mounted to the seat slider, whereas the earlier ones, like yours, had the belts mounted to the tunnel of the car. I'm not sure, but I've heard that the threaded holes for mounting the belts to the tunnel are there on the later cars under the carpet.
Dan
Former owner of: '88 924LE (Luddite Edition) manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5 torsions, 931 valance and header panels, 6X16 Fuchs, lowered, etc, etc.
Old 10-15-2009, 03:57 PM
Architect / Car Guy
carlege's Avatar
Send a message via AIM to carlege
is that not a sport seat in the driver side? looks like it has the side padding of a sport seat
Looking Forward to getting my First "car" Porsche 951
Old 10-15-2009, 04:02 PM
naw the sport seats are much more bolstering than that.
yea on my 83, the seat belt buckle bolts onto the tunnel, not the seat.
Old 10-15-2009, 06:20 PM
VII VII is offline
That is a normal seat? Then I'm confused as to what my seat would be...It looks the exact same except the middle portion of the top and bottom is gray cloth with "porsche" as a pattern. I figured I had a basic (normal) seat and that the full leather-ish seats were a fancier version? Perhaps the version I have is for the power seat option (as mine are power seats)?
Old 10-15-2009, 06:48 PM
your average wrencher...
seat
it looks like an old 924 seat...
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 10-15-2009, 07:10 PM
yer sound like mine. with the porsche script cloth.
Old 10-15-2009, 09:16 PM
Toofah King Bad
Rasta Monsta's Avatar
Those are def 944 seats. Whew!
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 10-15-2009, 10:29 PM
Thanks for the info! I'll check on the buckle mounting points when I disassemble the car. This will be a down-to-bare-metal-shell-and-back project just as soon as I get my last project (homebuilt airplane) out of the shop.
Rod Schneider
Ball Ground, GA
Old 10-16-2009, 03:22 AM
