Need tips to install fork lever pivot shaft
I am trying to install the clutch bellhousing but I am having a hard time lining up the fork lever after I place the bellhousing on the guide pins....what is the best way to do this? Thank you!
Old 06-24-2009, 01:06 AM
That Guy
Techno Duck's Avatar
You can line it up through the starter and clutch inspection hole with your fingers. Pull the fork pin out towards the holes and and pull it towards you. Then push it up towards the throwout bearing. It will catch the lip with the arms and automatically straighten out. Grease up the pivot pin and lock it in place.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 06-24-2009, 10:42 AM
