Redline Racer
What are the other 100 uses for Curil-T sealant?
I just got my next project's worth of parts from Pelican in today, including a tube of Curil-T sealant. The 1 use I know of, and is what I got it for, is sealing around the outside of shaft oil seals for extra leak prevention. My question is, what are the other 100 uses for it? It looks like some pretty good stuff, but what else is it good for? Oil pan gasket? ...or how about applied to the cam tower gasket, which is part of my upcoming project? Does it work as a flange/case sealant as it seems to suggest on de box "Specially designed for finely machined sealing surfaces."
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=PEL-246948&catalog_description=Curil%2DT%20Sealant%2C%20%37%3 5%20ml%20tube%20%20%20%20 Thanks in advance for any enightenment.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
