-   -   AC blows cold, but compressor cycles on/off: help? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/482910-ac-blows-cold-but-compressor-cycles-off-help.html)
wild man 09-10-2009 08:49 PM
Originally Posted by Crimson Nape Racing (Post 4885657)
Mark - mine was doing the same thing (cycling every 10 seconds or so), and I finally figured out there was too much freon. The high pressure side was 275-300 psi at idle. I bled a small amount of freon back into the canister and mine works like a champ now. I cannot keep the temp all the way down or I will freeze (even in 100 degree Memphis heat). You guys who complain about bad a/c need to drive old 911's for a while :)
Might be the case, but doubt it will hurt it, and means longer stretch of time before it will need some added again. If it stops cycling completely, it will be getting warm soon. I'll pass on the old 911's, thank you.
MarkRobinson 09-11-2009 06:30 AM
I think mine is under-filled: about 905 grams vs the 950 required. I'll probably check it next month: my 928 ac went out, fixing that first since the 951 still blows cold :)
wild man 09-11-2009 07:46 AM
Mine is a little over now because it ran too low (and therefore warm) before the season was over, and I had to add some more, after filling it once at the start of the hot season here. But it really needs to be working year-round, as it significantly improves defrosting capability.
If you see a continuous stream of bubbles in the sight-glass, then it is definitely under-filled. You should only see them for a few seconds after the compressor cycles on, then they should disappear. This is the reason for having a sight-glass!
MarkRobinson 09-11-2009 07:47 AM
i'll look at this tonight: thanks for the tip. :)
John_AZ 09-11-2009 09:34 AM
Just to add to wild man, the sight glass works OK for R-12, If your car has R134a (OP has R12), the sight glass is not an indicator and most R134a vehicles do not have a sight glass in the receiver-dryer-----new or correct conversions.
GL
John_AZ
wild man 09-11-2009 10:56 AM
GL
John_AZ
Thanks for the FYI, John. I was not aware of that. I must be older-school than I realize.
peon77 07-26-2010 05:44 PM
mark,
did you ever find out the cause of your compressor cycling? I am having the same issue with a similar system story.
Pete
