Looking for schematic for the climate control unit
I had a shorted A/C compressor clutch that fried some of the circuitry in the control head. The unit now smells when the A/C is engaged, so something's badly damaged in there. I can fix it if I can get a schematic for the unit. Anybody know where I can get one?
Thanks, Stephen 87 944 NA |
Just thinking out loud
I think you are going to have to research all the way back to the manufacturer of the control head. I'm sure you knew that, but in case you didn't... In my browsings, I have never run across such a diagram in the factory manual. I've soldered a board or two, but help wasn't there. You are most likely going to have to crack it open, find the burnt traces, then jumper.
That's all I got man, sorry.
83 944 91 FJ80 84 Ram Charger (now gone) |
