Red face 924s help losing my mind
is there any way to test the dme it self on an 88 924s i adjusted the reference sensors checked for grounds i've tried every thing but nothing has changed since my last post
Old 07-03-2009, 04:35 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
DME is hard to test. Send it to George at 944 ecology or IAN at 944 online. There is suppose to be a test procedure in the factory manuals but I've never read it so I don't know for sure there is or how complicated it is to do that.
Don't remember your last post...what is your problem?
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 07-03-2009, 04:44 PM
Maybe you could borrow or purchase a known working DME for your car to see if it solves your no start problem..
Old 07-03-2009, 05:05 PM
Not sure what your last post said, but when I did my head job, I mistakenly swapped the speed and reference sensor connectors. Drove me nuts, until I relooked at everything. That was when I realized what I had done wrong
86 951 blk
Old 07-04-2009, 05:15 AM
sorry forgot to copy last post here it is 924s no start
Old 07-04-2009, 08:59 AM
Ok, so let's start from the beginning....
Voltage at coil with key on? Black wire should have 12V or more. Check it also during cranking as it needs it then as well and it's a different set of contacts and wires.
Voltage at injectors? No voltage here but at the coil, then DME relay is the problem or broken injector harness which is a common problem. Put the jumper wire in DME relay socket to test that. (Even new ones sometimes fail; using a jumper wire eliminates the possibility completely and it's easy to make one). Fuse box connectors also have been known not to make contact to get the 12V to the injectors...so look them over and use a volt meter there to make sure you have voltage at pin 30.
Should also have 12V at 18 and 35 on the DME plug.
Let us know what you find from these tests and we'll go from there.
Tom
Old 07-04-2009, 02:52 PM
