-   -   Spark problem! (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/484384-spark-problem.html)
shogunther 07-08-2009 10:54 PM
Spark problem!
Hey guys,
I am having a intermittent spark problem. When I turn the engine over I get a intermittent spark...sometimes the first revolution...sometimes the 4th....its just random. I have two DME's the first was the one that came with the car and I bought the second to see if the first dme was bad. The first dme gives me more spark than the 2nd one. I don't know if either one is good.
Here is what I have done so far:
1. new speed and ref. sensors (gapped them but still no tach bounce)
2. new dme relay
3. new dist. cap, rotor, plugs
4. checked coil
5. checked ignition switch at #4 terminal on DME plug and ground (10.5 V)
6.
When I turn the engine over I can hear the ignition relay clicking alot...is this normal? Any ideas on what might be causing the spark problem?
trivgar 07-08-2009 11:43 PM
Wiggle the plugs around for the speed and reference sensors while cranking it over.
