-   -   Valve springs replace or not? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/485066-valve-springs-replace-not.html)
bazar01 07-13-2009 09:02 AM
It started as a rod bearing replacement and block bellhousing thread repair.
Decided to pull the head and inspect the headgasket. Glad I did since I noticed the headgasket was already powdery and easily crumbled on some spots which were I think some signs of slight overheating. Lots of carbon build up too as well as on top of pistons. Cylinder walls were perfect. No score lines.
Rod bearings showed minimal wear, no copper showing at 200k miles. Plastigage showed 0.0025". Wear limit is 0.0068". :D
Sent the head out for servicing. Will buy a headgasket set, camshaft chain and pads.
Questions:
1. Do I need to replace the valve springs even if they were fine? 200k on the engine. Do they break? Car has never been raced.
2. What about head studs?
Just the nuts maybe?
Pics to follow. Thanks.
bazar01 07-13-2009 11:05 AM
Searched and found out nobody changed the head studs, just the nuts with no issues.
Nobody also seemed to be replaceing broken valve springs on the 16 valves.
Looks like the double springs on the valves are strong enough to take the beatings.
Now, I found some reports of broken valve springs on 911s. What's up with 911 valve springs?
running_cold924 07-13-2009 11:15 AM
i'd put her back together with what you are doing now, sounds good
John_AZ 07-13-2009 12:42 PM
You may want to upgrade the normal HGS valve stem seals. I used the set that came with but many upgrade.
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/479821-whats-correct-valve-stem-seal-944-na.html?highlight=valve+stem+seals
GL
John_AZ
bazar01 07-13-2009 05:54 PM
Thanks John for the suggestion.
I already placed the order for the Victor Reinz head gasket set with valve stem seals. So i will just use whatever comes with the set. Also just ordered the head nuts. I will reuse the valve springs.
At 200k miles, I figure if I get another 100k we'll be happy.
nynor 07-14-2009 03:03 AM
i'd be for changing the head studs, if they are the original studs.
bazar01 07-14-2009 07:11 AM
Thanks for the suggestion.
I have thought about replacing them until a 944 guru had mentioned he never had a problem reusing them. This is the first time so I will reuse them and replace on the next rebuild if the engine lasts that long. Or will just go to a 968 engine next time.
Cylinders were fine:
http://forums.pelicanparts.com/uploa...1247579945.jpg
Head:
http://forums.pelicanparts.com/uploa...1247580104.jpg
Gasket:
http://forums.pelicanparts.com/uploa...1247580224.jpg
http://forums.pelicanparts.com/uploa...1247580355.jpg
