sl66ICEcuba's Avatar
944 NA 2.5L chip worth the money?
I am looking into a chip from Lindsey racing for my 88 NA, I only use 91 octane fuel. I tried searches looking for past experiences but couldnt find anything. Has anybody here tried them? pos and neg? is it worth the 250 dollar price tag?
thanks a lot
*1988 944 NA with front end Turbo Conversion*
*1968 400 cubic inch bored and stroked Firebird*
Old 07-19-2009, 10:05 AM
Proprietoristicly Refined
John_AZ's Avatar
I am not a fan of chips. I would rather do all the neglected maintenance and upkeep--which is required before you install a chip in any case.
I do have the "improved" throttle cam (+- $30) on my "87 and there is a big difference off the line. The "improved" cam does use more gas and my mileage suffers.
Here is a "PRO" answer to a few questions.
http://germanautoforums.com/forum/showthread.php?t=7240
GL
John_AZ
1988 924S 60K + 1987 924S 113K
Old 07-19-2009, 10:23 AM
Send a message via AIM to ScoobySteve
thanks a lot
I think it's worth the money. It doesn't really make you that much faster, but it increases driveability considerably. You may also consider the FR Wilk chip, which is what I have.
-Stephen
00 Boxster S 6MT
03 Subaru WRX w/EJ207 swap
16 Cayman GT4
21 Genesis G70 3.3T
Old 07-19-2009, 10:24 AM
John_AZ's Avatar
and of course I will disagree...
http://www.connact.com/~kgross/FAQ/944faq13.html
But if you must-last sentence copied....
See if you can find a used one. Damage for the normally aspirated cars is unlikely to result, so you might as well pick up a chip cheap. If you buy one new, make sure you buy from a vendor that lets you return it "no questions asked". If the chip doesn't live up to your expectations, you can return it.
BONUS! Throttle cam for free!
http://www.dietersmotorsports.com/tech/2001/944_throttle_cam.htm
GL
John_AZ
Old 07-19-2009, 10:49 AM
unindicted co-conspirator
looneybin's Avatar
i have the FR Wilk chip.
It's worth the money as far as i'm concerned.
It reworks the timing and fuel curve for smoother acceleration
It does not add any power, it just moves it around
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 07-19-2009, 05:03 PM
