-   -   How are valve stem seals correctly installed?!? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/486047-how-valve-stem-seals-correctly-installed.html)
John_AZ 06-18-2013 05:30 AM
Van on RL used a different type tool ---just FYI
Changing Valve Seals - Rennlist Discussion Forums
J_AZ
djnolan 06-18-2013 01:08 PM
This is all very helpful. Before I tear in to it, I plan to do a leak-down test. If the #1 plug is fouling up with oil and the leak-down test results are good, then is it for sure the valve stem seal? Is the #1 cylinder the usual place for the first signs of valve stem seal problems? The other plugs seem nice and tan in color. Approximate oil consumption is 250-500 mi per qt.
