924 v 944 brakes
Are the early 924 brakes the same or similar to the early 944 brakes? I found an early 924 parts car but not sure if the parts vary at all. I am referring to hubs spindles for the front and rear trailing arms
zak
Old 07-17-2009, 02:13 PM
Fallow up. If it is not a 924s is it hard to convert from 4 lug to 5 lug, I believe it is just the hub and rotor but would the caliper work or would that need to be changed.
Old 07-17-2009, 02:23 PM
Non Compos Mentis
Early 924s had drum brakes in the rear, and used four lugs. Not the same as 944 brakes at all.
Old 07-17-2009, 08:21 PM
Turbonut
Raceboy's Avatar
No it's not hard, just need to get parts from donor car.
Front: spindles, hubs, calipers, rotors, dust shields
Rear: rotors, hubs, calipers, dust shields and caliper mounts. Also parking brake cable as this is different from 924 NA.
It's a 3-4hours job and front needs alignment after that (because of changed spindles).
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 07-18-2009, 02:57 AM
924RACR's Avatar
A few other minor diffs, but the suspension arms can be used even if it's a 4-bolt. If converting, there are short hard (steel) brake lines between the hose and the caliper in the rear - either need to take those over (for the 5-lug setup) or (preferable) bend up new ones.
Also, a point often missed when doing the conversion - brake plumbing needs to be changed from X-split (LF and RR on one brake circuit, LR and RF on the other) to what's known as TT or H split (fronts on one circuit, rears on another) - which is what the 944 had. Otherwise your braking will be all F'ed up.
If you're looking to source spare parts from that parts car to a 944 - Raceboy has pretty much covered what's different, so most anything on that list could be used, plus the front calipers on the 4-bolt setup become the rear calipers on the 5-lug.
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 07-18-2009, 05:23 AM
Turbonut
Raceboy's Avatar
Vaughan, 924NA front pistons are bigger diameter than 924S/944 rear pistons. So with stock 944 fronts it will be messed up balance.
Old 07-18-2009, 11:57 AM
924RACR's Avatar
Ah, OK, sorry, my bad!
Actually... that could lead to interesting possibilities for the racetrack, if you wanted to mess with adjustable bias! I don't, but if you wanted adjustable... well first crank up the rear brake torque too high (using these calipers), then limit it back with an adjustable bias valve...
Vaughan Scott
http://www.924.org
Old 07-19-2009, 05:57 AM
