rickharrison's Avatar
stuck snap ring on t-stat!
Help! The snap ring is stuck, and probably the original, so its stuck and hard to get out.
Any tips?
TIA
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 07-24-2009, 07:13 AM
does it not compress with the snap pliers? or what.
Old 07-24-2009, 07:24 AM
well, its supposed to.
Rick Harrison
1988 944S
MaxHP chipped
Old 07-24-2009, 07:42 AM
so what's the problem? if it compresses, it should just pull out.
Old 07-24-2009, 08:00 AM
Registered Speed Offender
Crazy Horse's Avatar
Persistance...
I just went through this same problem.
I was able to get a short screwdriver and tap (with small hammer) against the side of the snap ring all of the way around. There was just enough "give" in the t-stat gasket to have slight (micrometer size) sideways movement - which is enough to loosen. I then tapped on one of the ends of the ring to turn it in the housing around to the 11:00 position. I took a 90 degree set of snap ring pliers, cut them short and bent to fit. Idid remove the oil filter and coil for better access.
A real PITA, but it will eventually come out.
Good luck!
Crazy Horse
______________
1989 930
Old 07-24-2009, 08:26 AM
Ok...that's what I'll do then. Thanks crazy.
Rick Harrison
1988 944S
MaxHP chipped
Old 07-24-2009, 08:41 AM
I did this recently. Working from underneath, with car secured on jackstands. Used 45 degree snapring pliers. Not easy, but it will work if you keep trying. '83 944.
Old 07-24-2009, 08:49 AM
