Kirby2's Avatar
Running out of steam
My 944 N/A wants to die and refuses to start when it has been driven more than 10 or 15 minutes, leaving me stranded on any roadway that I have to stop.
Has anyone had this warm engine no-run problem.
When it runs, it purrs like a kitten. Fresh cap, rotor, wires, plugs recently installed. Passed CA smog with flying colors.
03 Silver PT Turbo - Ours
86 White 951 - His
86 White 944 Manual - Hers
98 C-4 Sons
86 Gold 944 Auto - Sons
84 Maroon 944 Auto - salvaged
78 Yellow 924 - found a new home
Old 08-04-2009, 06:57 AM
Toofah King Bad
Rasta Monsta's Avatar
Pop in your spare DME relay and see if the problem resolves.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 08-04-2009, 07:16 AM
Architect / Car Guy
carlege's Avatar
Send a message via AIM to carlege
http://forums.rennlist.com/rennforums/showthread.php?t=515761&referrerid=69439
guy on rennlist had the same prob... could be a few things. His was leaking injectors
Looking Forward to getting my First "car" Porsche 951
Old 08-04-2009, 07:59 AM
West Central Ohio 45380
plyhammer's Avatar
Mine was negative battery cable that wasn't tight enough?
Old 08-04-2009, 08:10 AM
In the Fires of Hell.....
kdjones2000's Avatar
Other possible causes:
1) Reference/Speed sensor are dying (Connectors or the actual sensors)
2) DME computer has bad solder joints
Others as well, but those come to mind right away.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 08-04-2009, 10:17 AM
