bleeding the clutch
i had the clutch completely disconnected and the line going to the slave cylinder is completed empty of fluid. where is the reservoir for the clutch, is it the same as the brake? or how do i go about bleeding the clutch lines.
Old 07-25-2009, 10:41 AM
Go to Clarks-Garage.com and look it up.
Cheers,
Larry
Old 07-25-2009, 10:44 AM
Redline Racer
HondaDustR's Avatar
I actually saw a vid on youtube that showed a BMW mechanic demonstrating how to bleed in reverse. Just buy one of those little hand pump oil cans and pump the brake fluid from the bottom up. Made all the sense in the world, since air always tries to go up, and you're trying to suck it down. Haven't needed to bleed the clutch since then, but I would try it!
here's the link.
http://www.youtube.com/watch?v=wdf--suwqw0
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 07-25-2009, 10:58 AM
Proprietoristicly Refined
John_AZ's Avatar
The video procedure works well. I suggest taking the clutch MC rod off the clutch petal--has only a slip clip removed with finger. There can be no pressure on the clutch MC rod from the clutch petal.
GL
John_AZ
Old 07-25-2009, 11:01 AM
The clutch uses the same reservoir as the brakes.
To bleed the clutch system secure car on ramps or jack stands. Remove the starter and bleed the system with the bleeder fitting on the slave cylinder, like bleeding a brake caliper except with the clutch pedal. Bleed several times to get air out of both clutch cylinders.
The clutch slave cylinder is directly above the starter.
Old 07-25-2009, 11:03 AM
its all bled with no air pockets but the clutch petal just goes all the way to the floor and doesn't try to retract.
Old 07-25-2009, 11:38 AM
Feelin' Solexy
Tishabet's Avatar
I assume you just replaced your master and slave? If not, this means that one of them is bad.
So assuming you just replaced them...
Unless you screwed around with the "recall" spring, the failure to retract likely means that you in fact do still have air in the system. I would recommend using a small fiber hammer to give the master and slave a few good taps, then bleed again.
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 07-25-2009, 12:23 PM
Toofah King Bad
Rasta Monsta's Avatar
Get a Motive Powerbleeder. Works perfectly for clutch and brakes, and can help you with your overdue brake fluid flush (every TWO years).
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 07-27-2009, 09:01 AM
