LinkBack | Thread Tools | Rate Thread |
Proprietoristicly Refined
When this happens, do you hear the fuel pump hummmmm?
If not, the typical cause is the DME/fuel pump relay. It happens so often, many carry a spare or the 3 wire jumper you can build if you look at www.Clarks-Garage.com. If you did hear the fuel pump, it could just be bad battery cable connections at the battery or begin to clean ALL of you grounds. Here is a pic from TecnoDuck: ![]() Then it could be the ignition switch contacts--and for our cars $4 Pelican price is a good deal. GL John_AZ |
Toofah King Bad
Listen to John. Call him Wise John. Give him offerings.
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Thank you Rasta for the kind approval
![]() I see you finally sold your car ![]() ![]() http://forums.rennlist.com/rennforums/924-931-944-951-968-forum/516951-my-new-924-a.html John_AZ |
still wont start
i havnt had any time realy to mess with the car but i did change the filter because i thought it may be pluged and not letting fuel get to the fuel rail but i changed that and no change. then my buddy showed up and i had him crank the car over to see if it was pumping and it made no noise (the pump), so just to reassure this i pulled the fuel line off the fuel rail and cranked the car over and it should have shot a stream out but not hardly even a drop came out.
by the way this has been a reoccoring problem but ususally it starts up if you shut the key off and try it again but this time it just stalled instantly and wouldnt start up (first time it happened going down the road, when it did it before it was after the car was setting for a couple hours or over the course of a day at work. so my next step is to check the relay with jumper wires and check the fuel pump off the car with a little power to see if i can make it run. but if any one has a good suggestion on how to go about this or a better elimation process i will be more than happy to get some more help thanks guys Last edited by ktmfreak2004; 08-10-2009 at 10:05 AM.. |
Grounds or DME relay.
Rick 93 968 (My summer car), 05 Cayenne S (My winter car), 79 924 (Wife's summer car), 02 C230k (Wife's winter car), |
that is what i am hopping for cause i dont want to buy a expensive fuel pump @ $230.
i just for the heck of it went out side to goof with the car and tryied tapping on the relay and hit the key and it started right up so i am going to try getting new relay and see how far that will get me
Try this. http://www.dietersmotorsports.com/tech/2001/DME_relay_failure.htm GL John_AZ |
It is always best to keep a spare DME Relay in the glovebox or a 3 wire jumper. Ref: clarks-garage.com.
Cheers, Larry |
I am going to buy 2 of them today and 1 to fix the car and a spair and just for the heck of it i am going to try fixing the old one like john_az suggested
thanks guys on a differnt note any one herd of the sunroof cable running its self all the way out and not running the other way?? I think that it is the switch failing |
Thread Tools | |
Rate This Thread | |
