Flatsixhead's Avatar
Red face Master Clutch Cylinder Replacement
Ok not so new 951 owner is losing his mind again.. Pulled the directions from Clarks Garage to remove the clutch master and am really stuck because there is zero room to get to the bolts on the fire wall, the hose clamp and to disconnect the main line into the master. It appears that some of the items that are in the way could be removed but I'm afraid to really mess something up. Any suggestions from the pro's out there?
Old 07-27-2009, 03:12 PM
Proprietoristicly Refined
John_AZ's Avatar
I just did mine a couple of months ago on the '87 924S. I do not know if the 951 has more tubing and wires near the brake booster but after you drain the brake MC reservoir below the tube for the clutch MC and unbolt and unclamp anything in your way---it does make getting to the 2 nuts easier with and extension and a universal swivel. The nut came free very easily and I was using a 1/4 inch set and 13mm socket.
GL
John_AZ
1988 924S + 1987 924S
Old 07-27-2009, 05:37 PM
1984 porsche 944 na
ballysdad's Avatar
just take out the stuff that is in the way and you will be able to get a wrench in there. It's not that bad and they are usually easy to come off. The clip on the clutch pedal is the pain in the job.
1984 Red NA/Sold
1984 Gray NA/Sold
1986 Red NA
1986 Gray NA
Old 07-27-2009, 05:42 PM
Yes sir.. There's more stuff in the way in a 951. So much in fact that once the nuts are removed there's no room to pull the master out. I guess I'll start trying to remove some of the blockers. My wife is PO'd because I keep spending $$ on this project and I'm pissed because it's really nice out and the cars stuck in the garage.
Old 07-27-2009, 07:02 PM
drift a 944's Avatar
Where are you from? Maybe another local pelicanhead can offer some assistance with the project. If you live in Orlando I'd be glad to help out with anything, but what would be the odds of that?
You will get it with some time, good luck!
- Elliott Grafton - 944Barn
Old 07-27-2009, 07:35 PM
flash968's Avatar
do the other 2 components (slave and high pressure hose) if they have not been changed in the last 5 years - one strong and fresh hydraulic component almost always results in finding the weak remaining one and blowing it
Old 07-28-2009, 08:27 AM
Thanks Flash - I bought both the slave and the master and the hose appears to be new and does not have the factory clamps (They are steel). I live just outside Chicago in La Grange if anyone can assist. ( I will be happy to pay in beer / pizza and or cover any travel time expenses for an extra set of hands / experience)
Regards
Dan
630.460.0505
Old 07-28-2009, 10:58 AM
Master Problem
What can I remove to get to the Clutch Master?
Old 07-29-2009, 04:58 PM
Toofah King Bad
Rasta Monsta's Avatar
Same on both my cars, man. Dig it out. Got a wobbly 6" extension?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 07-29-2009, 08:26 PM
exitwound's Avatar
Yeah, my n/a was cramped. Used a wobbly socket. Only took 2 days to change it out. In the snow.
-Patrick
Black 1986 944
Old 07-30-2009, 07:20 AM
p-talk's Avatar
I was able to get mine changed in 30 minutes. Wobby extension was key. But I've got an early NA, possibly less stuff in the way but it WAS tight. You had to play "tetris" to get it out, but it DID come out.
1984 Porsche 944 - Mathilda the needy
2014 Audi Allroad - daily driver
Old 07-30-2009, 08:25 AM
exitwound's Avatar
You can come do mine next time I have to change it
-Patrick
Black 1986 944
Old 07-30-2009, 10:04 AM
p-talk's Avatar
Sure thing if I'm in the area . The Porsche gods got me back on the clutch slave though - broken lower mounting bolt, drilling out, tapping, major suck!!!
Old 07-30-2009, 10:22 AM
Porsche Crest Thanks guys..
I gonna yank that puppy OUT!! On the way to the parts store to get some specialty tools!!
Old 07-30-2009, 04:22 PM
exitwound's Avatar
If you can, check to see that the firewall hasn't cracked where the master cylinder connects. Hopefully it hasn't. Good luck!!
Also, bleeding the clutch is as much as a major payne as Damon Wayans! Have you done it before? You need DOUBLE GOOD LUCK on that one.
-Patrick
Black 1986 944
Old 07-30-2009, 05:41 PM
ok - I finally pulled the old master out and inserted the new one but how can you thread the nuts if you can't reach them? This car continues to LOL at me..
Old 08-08-2009, 08:21 PM
p-talk's Avatar
If I remember correctly I used a thin magnet tool (that I usually use to fish sockets or screws out of the car that I've dropped ). I was able to get the nut on the bolt, then get a finger in there to start threading. YMMV . .
Don't let the car win!
Old 08-10-2009, 08:23 AM
flash968's Avatar
insert the nut into a socket on a universal joint on a 12" extension - if your u-joint is too floppy, try a dab of silicone in the socket to hold the nut in there, and a gob of it in the u-joint to help prevent it from flopping around
Old 08-10-2009, 08:26 AM
I've tried everything to thread the nuts and am waiving the white flag!! Two nuts away from driving the car is killin me.
Old 08-12-2009, 03:56 PM
exitwound's Avatar
All you have to do is get one on to hold the cyl in place. Then the other can be done after coffee, or tea, or a movie or something when you stop throwing things.
-Patrick
Black 1986 944
Old 08-12-2009, 04:36 PM
