LinkBack Thread Tools Rating: Thread Rating: 1 votes, 3.00 average.
Advice on chainging the Brake Proportioning Valve - 968
I have a 92 968 that according to the parts diagram the brake proportioning valve is attached to the ABS unit rather than the master cylinder. I have checked to verify this and have found it to be a bit difficult to locate. My questions are...
Am I blind. I have changed out the ABS unit on my 5 series. I know what they look like. How can I be having difficulty finding this thing.
As it is attached to the ABS unit are there any special instructions I should know? (Other than really bleed the system after the swap.)
Any pitfalls I should know about?
Thanks for any help you can offer. I appreciate it.
TomR
92 968 Track Toy
99 528 DD
06 Saab Sportcombi - Family Truckster
Old 08-18-2009, 07:43 AM
That Guy
Techno Duck's Avatar
ABS unit is located behind the fender liner in the passenger fender. Nothing special really to do, just bleed system as you said.
Old 08-18-2009, 08:08 AM
flash968's Avatar
that is where it is - it is screwed right into the top of the ABS unit - a pain in the butt to change too
it would be a lot easier to change with the fender removed
prepare to get soaked in brake fluid
you have a PM
Old 08-18-2009, 08:32 AM
