Does headlight motor reverse?
Does the motor do a full rotation just stopping at the right places, or does it reverse? I'm putting this stuff back in after a long time and there seem to be things in the way if it were to go all around.
Trying to find a new connector, or I would be trying it to see. Thanks |
in normal operation, it just keeps on going one way and stops at full up and full down.
If you need to reverse it to fix a jam, or if it fails, you can manually turn it forward or backward by removing the rubber motor cover and turning the knob on the rear (top) of the motor.
Thanks. I don't need to reverse, just need to make sure there is space. It looks like the hood release cable will be in the way.
| All times are GMT -8. The time now is 01:50 PM. |
