Disconnect ABS Light 89-944S2
1989 944S2. My ABS has been dead for 4 years. I have replaced the relay, and I bought a wheel sensor monitor - and replaced 2 wheel sensors. The ABS warning light is off at startup - but comes on after driving about 100 feet.
After 4 years I am tired of looking at the dashboard ABS warning - plus is masks other warnings.
I doubt that I will ever repair the ABS - and, now, I just want the warning light to go away.
How can I turn off the ABS warning indicator- but keep other warnings ?
Dick
Old 08-15-2009, 05:19 PM
Non Compos Mentis
On my old S2, the ABS light would illuminate on a regular basis. Turned out to be just a loose ground connection under the right front wheel well. Hitting a bump would be enough to wiggle the connector just enough to loose its continuity for a split second. that was enough to trigger it, and it would then stay on until the ignition was cycled off and back on again.
Old 08-15-2009, 06:59 PM
ABS relay
Dick
What will happen if I just pull out the ABS relay???
Dick
Old 08-18-2009, 09:07 PM
Just unplug the T40 connector under the dash on the passenger side just above the DME.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 08-19-2009, 02:51 AM
RedBaron's Avatar
Look on ebay for a slightly used ABS computer. The relay and that was the problem on my S2 (I had a leaky battery box and the computer and the dme are right underneath that on the passenger footwell).
You could also try and get your local Porsche garage to test it using a special Bosche testing unit and that tells you what it is right away. My local Porsche garage tested it for me for free and I bet you if they are not busy they would gladly take a look for you.
Old 08-19-2009, 05:46 AM
Lucky you. I have taken my 1989 944S2 to 2 different Porsche dealers (one was 300 miles form home) - and neither could diagnose the ABS problem. Both dealers told me that the '89 944S2 needed a "special" plug to hook up to the computer - and that they did not have one.
If you have a 1989 944S2 - please tell me who and where your dealer is and I'll make another trip.
Dick
(in the heartland)
Old 08-21-2009, 02:27 PM
AKA J BERK on Rennlist
jsb944's Avatar
I had the identical problem on my 91 S2.....bought a used computer and Pump (from LART951) at a very reasonable price and had my mechanic install them.
Now I have ABS and no light anymore !
Fix it.....
Joe
Current: 2014 Cayenne S
Gone but missed:
2003 996 C4S; 1991 944 S2; 1984 944 NA
Old 08-22-2009, 03:10 PM
RedBaron's Avatar
Dick
(in the heartland)
I have a 1989 Guards Red 944 S2 and I went to Hoffman Porsche (Dealership) in Hartford, CT and they tested it for me. You could always try and come up on a weekend that there is racing at Limerock Park so there is something else to do.
Also, keep your eye open on ebay for an ABS test booklet for the 944. I have seen a few on there before...
Website: http://hoffman.porschedealer.com/
Old 08-23-2009, 04:06 PM
Feelin' Solexy
Tishabet's Avatar
I believe the testing unit you guys are talking about would be the Bosch "Hammer." I think any decent Porsche shop should have one...
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 08-24-2009, 11:24 AM
So, I have been to 2 "Indecent" Porsche dealers? - Iowa and Minnesota.
Anyone know a "decent" porsche dealer in Chicago ? That's about 4 hours away for me.
Dick
Old 08-25-2009, 12:46 PM
slow944s's Avatar
I was thinking I'd heard about a decent shop in the KC area, I have been wrong before though.
84, 944 Silver--Crashed and burned.
87, 944S White--Daily driver
Old 08-25-2009, 06:57 PM
