low idle with A/C on?
My daughter complained about her car stalling when coming to a stop. I drove it that night and had no problems. The next day I did some work on it and I noticed that when the A/C is on, it the idle does drop to sub 500 RPM. I pulled the intake and sprayed in some carb cleaner in the ISV and tested it. It works fine. When the A/C is on the idle should come up? How much?
Thanks for any other suggestions.
Rick
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 08-25-2009, 03:21 PM
Registered Speed Offender
Crazy Horse's Avatar
Check the AC idle air solenoid
On my car, mounted to the back air cleaner box attachment plate, is an AC idle air solenoid. I know this because it was disconnected when I got the car from the PO. After asking questions on this board, I realized what is was, that it was disconnected and that I needed to reconnect the wires to it. Before, when I turned on the AC, the car would idle about 300-400 rpm lower when the compressor kicked in. Now there is almost no change when the compressor kicks in.
Does your car have this solenoid?
Crazy Horse
______________
1989 930
Old 08-25-2009, 04:11 PM
Redline Racer
HondaDustR's Avatar
I think that solenoid was only on the early 944's. I think the later ones sent a signal to the DME from the AC relay, or something to signal an idle compensation setting.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 08-25-2009, 05:06 PM
I disconnected the ISV and the idle goes up to about 1100. If I plug it back in the idle drops and it will stall.....
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 08-25-2009, 05:15 PM
Proprietoristicly Refined
John_AZ's Avatar
The ICV/ISV valve is not giving the DME a correct signal. You may have vacuum leaks in the in and out hoses or the valve is dirty.
There have been a couple recent posts on how to clean the ICV/ISV or go to www.texasblake.com and see his writeup.
The ISV/ICV replaced the early solenoid.
GL
John_AZ
Old 08-25-2009, 05:19 PM
