the guitar guy
Angry HOT AS #&@*^% HELL and I live in AZ. !!!
can't find cable for heater control ( hot or cold lever ) found cables for two other levers on drivers side but no movement anywhere with the hot/cold lever. is it on the passenger side ? HELP
Old 09-04-2009, 02:28 PM
my control knob doesnt effect the cable by the drivers foot, but if the clip breaks, the ''valve'' goes to full hot, so try moving it the other way and securing it somehow.
-1986 944 NA
Old 09-04-2009, 02:48 PM
the guitar guy
just found it, in engine compartment center-ish near firewall
Old 09-04-2009, 02:54 PM
the guitar guy
now does anyone know what the clip looks like for this heat stopping marvel, i could just put a zip tie on it and move on to other projects but i sure would like it to be right.
Old 09-04-2009, 03:06 PM
Proprietoristicly Refined
John_AZ's Avatar
From www.944online.com (credit)
The white clips
GL
John_AZ
1988 924S + 1987 924S
Old 09-04-2009, 04:53 PM
Toofah King Bad
Rasta Monsta's Avatar
So, they don't have U-Hauls there?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-04-2009, 10:55 PM
John_AZ's Avatar
RR Guitars,
I reread the thread and had brain burn.
Here is the heater control valve and the "clip"
GL
John_AZ
Old 09-05-2009, 05:08 AM
the guitar guy
thanks john !!!
i looked at all the threads for the heater controls ( and my heater has cables not rods with clips so all the pictures didn't look right) but the hot/cold lever cable seemed to be no where to be found. i ended up moving the lever back and forth, and watched which cable flexed a little, only to follow it into the engine compartment. thanks soooo much for those second set of pictures. priceless !!! thanks again i see your in carefree, i'm in cottonwood, if ever in the area please look me up. oh and a business plug, if you have any guitars that need ANYTHING i would be happy to be of service. RR GUITARS now on to front wheel bearings oh boy !!
Old 09-05-2009, 04:54 PM
