-   -   Adding headlight relays (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/495540-adding-headlight-relays.html)
914efi 08-31-2009 06:16 AM
There used to be a guy selling good headlight harnesses, is he still around? If not where is good to buy either a good kit or the proper components? I have relay kits, but they all have short pigtails and will force me to bodge the wiring to mate with the car.
Tidybuoy 08-31-2009 07:16 AM
I bought mine at www.944online.com
and the fit was perfect. Made a huge difference in the brightness of my H4's.
RedBaron 08-31-2009 06:28 PM
Rennbay has a fantastic harness that also has another relay on the harness so it doesnt have a lot of current running through it.
http://www.rennbay.com/porsche-944-headlight-relay-harness-p-111.html?osCsid=91a8b64b8fdda694fcf63c69c4bade76
gpotts200 08-31-2009 07:31 PM
Anyone have a component list and wiring diagram?
914efi 09-01-2009 06:33 AM
I found one at http://www.advanceautowire.com/ that looks really good for about 50% of those noted. The relays and mounts look much better. I already ordered some a wire assortment to get started on my own, so I'll see how that shapes up and then maybe order this one. Wire is good for anything, so not too much lost.
They do also have a good schematic.
shikzachaser 09-08-2009 04:18 AM
I made mine for about $75 in parts cost. I used 10ga throughout and fused high / low independently. It is not that hard to do if you have any experience w/ 12V electronics. $134 is not bad if you just want a quick off the shelf item. Check my previous posts where I show what I made.
rennbay 09-12-2009 05:50 PM
We have put connector only kits together for those who wish to do it on their own. Connectors and uncrimped terminals for all the ends. Just give us a ring.
gpotts200 09-12-2009 07:59 PM
What is the cost of the kit?
