-   -   944s vs 944 questions? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/495987-944s-vs-944-questions.html)
85.5classic 09-01-2009 07:51 PM
So what are the major differences besides the 16valve and using the turbo's tranny??
Dantilla 09-02-2009 07:03 AM
The S does not use the turbo tranny. It uses an NA tranny with slightly taller gear ratios in 2nd-4th.
The major difference is the 16-valve engine.
Porsche-O-Phile 09-02-2009 07:38 AM
The "S" has a bit more power and will breathe a lot better at the higher RPMs because of the 16v setup.
On the flipside of that, there is also a heck of a lot more to break/go wrong on an "S" head and parts are a lot more expensive than their more common 8v brethren. The good news is that as long as you properly check the belts and tensioners/chains they're very robust.
85.5classic 09-02-2009 07:49 AM
hmm.. then nigel edwards book "924 & 944 classics in color" is completely wrong. They list the S and S2 as having the turbo tranny
Techno Duck 09-02-2009 08:40 AM
The gear ratios between the S and 951 is the same, its the final drive that is different.
The S2 is the same 1-4, with a shorter 5th and different final drive also.
thill944 09-02-2009 08:51 AM
I have owned the S and the NA. The 944S has about 30 or 40 more horsepower. I prefer the S to the NA.
Dantilla 09-03-2009 01:41 PM
Maybe my imagination, but my '87 S seems to be a smoother running engine than the 8-valve cars. Yup, I've got both.....
racer 09-04-2009 02:03 PM
the 16V says "Ventilier" all over the damn place! Plus the "S" on the back ;)
The other major difference is the cost to rebuild the 16V.
My other guess is that since Porsche never leaves their product alone, that there are dozens of little differences to drive you nutty too ;)
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
