944s vs 944 questions?
So what are the major differences besides the 16valve and using the turbo's tranny??
1988 Satin Black Metalic , Plaid interior 944 "Celebration Edition" Sold and now autocrossed in canada
1985.5 Guards Red 944na 66,000 miles (SOLD in 2002 )
http://porsche944celebrationedition.weebly.com/
Old 09-01-2009, 07:51 PM
Non Compos Mentis
The S does not use the turbo tranny. It uses an NA tranny with slightly taller gear ratios in 2nd-4th.
The major difference is the 16-valve engine.
Old 09-02-2009, 07:03 AM
Deplorable Member
Porsche-O-Phile's Avatar
The "S" has a bit more power and will breathe a lot better at the higher RPMs because of the 16v setup.
On the flipside of that, there is also a heck of a lot more to break/go wrong on an "S" head and parts are a lot more expensive than their more common 8v brethren. The good news is that as long as you properly check the belts and tensioners/chains they're very robust.
'74 911 Targa 2.7 (in storage, hoping to finish "someday"), 2001 Mercedes SLK 320 (with a few AMG fun bits), '85 BMW K100, a few surfboards
Black Cars Matter
Old 09-02-2009, 07:38 AM
hmm.. then nigel edwards book "924 & 944 classics in color" is completely wrong. They list the S and S2 as having the turbo tranny
Old 09-02-2009, 07:49 AM
That Guy
Techno Duck's Avatar
The gear ratios between the S and 951 is the same, its the final drive that is different.
The S2 is the same 1-4, with a shorter 5th and different final drive also.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 09-02-2009, 08:40 AM
thill944's Avatar
Smile
I have owned the S and the NA. The 944S has about 30 or 40 more horsepower. I prefer the S to the NA.
Old 09-02-2009, 08:51 AM
Non Compos Mentis
Maybe my imagination, but my '87 S seems to be a smoother running engine than the 8-valve cars. Yup, I've got both.....
Old 09-03-2009, 01:41 PM
racer's Avatar
the 16V says "Ventilier" all over the damn place! Plus the "S" on the back
The other major difference is the cost to rebuild the 16V.
My other guess is that since Porsche never leaves their product alone, that there are dozens of little differences to drive you nutty too
Past:
2000 Boxster 2.7, 1987 944
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 09-04-2009, 02:03 PM
