-   -   Just another idea to brighten up that cluster (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/497117-just-another-idea-brighten-up-cluster.html)
VII 09-07-2009 10:17 AM
Hiya. Just thought I would post up my simple approach to the dim cluster problem. I removed the old reflective material with acetone and put in new bulbs (in my case red) but for the reflector I used pieces cut from cut and stick side view mirror repair (about $8 at walmart).
Because the relector is an actual mirror, you're not losing any light to the low relection property of other fixes. Because I was only able to bend the mirror so much (I probably could have got a perfect fit with a heat gun, shaping the mirror) I did cover the whole thing with foil just to catch whatever light may have escaped out the sides. I used high temp hot glue to attach one side of the mirror then bent it and glued the other. I used hot glue to do a quick bulb socket repair about 4 months back and it still holds perfectly so I figure it should do fine until I get around to putting a couple drops of epoxy in. With the hot glue the whole process is reversible as it is not too difficult to remove later.
Seems to work pretty well. I need better red bulbs but they work just fine for now. This is not the end all of cluster fixes, just an idea I tried for those looking for a fix.
http://i564.photobucket.com/albums/s...4/DSC06162.jpg
http://i564.photobucket.com/albums/s...4/DSC06167.jpg
http://i564.photobucket.com/albums/s...4/DSC06171.jpg
http://i564.photobucket.com/albums/s...4/DSC06198.jpg
looneybin 09-08-2009 09:03 AM
nice look
I need to replace my odo gear again @#^%$
maybe i'll do that mod "while i'm in there"
