Creaky clutch
I have a 1987 944, and when I push down on my clutch pedal it makes a creaking noise. It only makes a couple creaks, and only happens when the pedal starts from it's resting position. Also, it does not make noise while being released. Suggestions???
Old 07-02-2009, 11:08 AM
unindicted co-conspirator
looneybin's Avatar
where is the creaking coming from?
if it's from under the dash, the pivot point or spring may need to be lubed.
spray some tri flow on the pivot point and where the spring attaches to the pedal & that should help.
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 07-02-2009, 11:47 AM
gpotts200's Avatar
I have the same problem.....did the tri flow work?
1984 Guards Red Porsche 944 NA
2005 Suzuki Forenza
2005 Suzuki SV650 **SOLD**
2008 Toyota Siena
Old 09-08-2009, 08:04 PM
